I bought one of those inexpensive bypass cables from Amazon but with my '21 Warlock, it meant disassembling the dash and removing the radio to access the SGM.
Plus, IIRC, I would have to remove this bypass before visiting the dealer for maintenance or warranty work. Just an enormous PITA!
I procrastinated installing the bypass cable until I found the KaodTech solution from a Ram Forum member.
It took about 5 minutes to install and no need to remove it before visiting the dealership.
If you have a 2018+ RAM and would like to perform diagnostics or make changes to the modules of your truck using tools like AlfaOBD or AutoEngenuity, this bypass is for you.Does this allow access to all modules?It has been tested connecting to the BCM and RFH. Since it bypasses the security...
www.kaodtech.com
BTW, I like the OBD interface that you listed. It costs less than 1/3 of an Mx+.
