Taillight question
Moodyeng
Can you change the individual bulb in a taillight or is it just a unit you have to replace now? is it just an LED unit?
I wanted to put a back up alarm bulb in it as I have had one in previous trucks I owned. i took it apart as much as I
thought I could.
Dean2
Near Edmonton
If you have LED tail lights there are no bulbs to change. If one of the lights go out you have to change the entire light assembly. If your taillights are bulbs then you may be able to do what you're trying. I have never heard of a backup alarm bulb.
Goes in where the regular old style, socket and filament reverse light fits.​
https://www.amazon.ca/Back-Up-Reverse-Beeper-Universal-Automotive/dp/B07518KM1M/ref=sr_1_5?crid=17S7Z3W8PIZ0S&dib=eyJ2IjoiMSJ9.p9FB7dK9TH81_FMqBVB4KP0-NYqMzOK45l8lhz95D-vPIdxvcvmOjmrw3RMeByrGxJOSct7_2aTWLoNtD0S7MVxtqiQhm01Vhu5dpZhpOT2faDIsc7-2Y_FbIytT07krIobY-dLEH7-uEGHcJsfCs1zJf9R9Gmebd75aLx8OpMgIFqH0RFKlimh0mROLUKc57QwQuiSra_ZzpSo9gFOci2Vekt4cLUae-8uudP-E5bbG4v40kj-2TSUZQAu5nVjVkaOgz-QyEKCknwO-xlFccAv8v78f1mLHVAkKihOieAw.NOp4OP0hF6IlSAYJZHhGxD8fmgos6DXERWeQGCOE-sQ&dib_tag=se&keywords=reverse+light+beeper&qid=1725129781&sprefix=reverse+light+beeper,aps,174&sr=8-5
Car Back-Up Alert Beep Light 12V LED Reverse Alarm Bulb Light Beeper Buzzer Lights Emits Beep Sound for Universal Automotive P21W,1156,BA15S,7506,3497,1073,1141,12498​
Brand: Timloon
turkeybird56
Central Texas
I believe the back up lights on the stock LED taillights are independent bulbs and can be changed.
IF U R talking about a 5th Gen LED tail light system, no. They R all LED and one sealed unit. I know, I had a cracked tail light that was replaced under warranty, good thing too, cause it was $550 ish dollars, I would have to look up to find exact amount.
FTR: The backup LED's in the 5th Gen Units Suk!!!!!!!
geneseedennis
