Tazer VS AlfaOBD
Bandit517
That Trials Guy
Wauseon, OH
I've been doing a little research before purchasing one over the other and figured it'd be better to make a post to hash out any details for future potential buyers.
My personal interests for either would be:
Full disable T/C-ESC without pulling F26 fuse
Disable Nav input lockout while driving (would be nice for passengers to enter addresses or POIs instead of needing to use voice commands)
Disable MDS
Global window control with fob
Power fold mirrors with ignition
Adjust idle
Change fan on-off temps
From the looks of my research the Tazer will do the power fold mirrors and Alfa will not. Aside from that everything else would be easier done in Alfa. I'm still researching details but if anyone has first hand experience with the Tazer and what it can and can't do feel free to let me know.
LoadedExpressRam
Gulfport, MS
Im not sure if either will deactivate mds. As far as power fold mirrors, alpha will allow to program but they wont fold automatically like tazer can. Also, the idle adjustment you mentioned is new to me as well. Im a little bias because i have alpha but i can say its probably one of the best purchases ive made regarding my truck. Also, im under the impression you have to leave the tazer plugged in at all times in order for it to work which probably isnt a big deal but alpha you do not. Either way i think both are decent purchases.
LeesEvoX
Houston, TX
Hemi 6.4l
The Tazer can do everything you listed above. Apart from Disable MDS, and change fan on-off temps.
Alfa wont be able to disable MDS either. Alfa ODB connects with the BCM (Body control module). MDS will be programmed into the PCM (Power control module), which Alfa doesnt have access too.
To add. The tazer DOES have a feature called cooldown mode. which turns engine fans on when ignition is on, engine NOT running.
Toddbigboytruck
Ontario
Disable MDS
Adjust idle
I really want to have the mirror to close when lock the door. I been thinking of getting a tazer. Which one do you have. ?
Dustyb1
Im in the exact same decision right now. I want to correct for tire size and enable led/hid lighting. I want the alpha obd but have failed for days finding a bypass harness, unavailable from kodatech at the moment. Considering settling for the tazer because its supposed to come with a bypass harnes... Any help is appreciated, its my first ram and this all unfamiliar.
LeesEvoX
Houston, TX
Hemi 6.4l
I'm happy with the tazer. Does what I need it to do. And has a few extras to play with.
Sent from my SM-G950U using Tapatalk
Andrew Dick
New York
I actually have both, I got the RamTazer first and it is quite good and easy to use. It will give you access to quite a few options that are just smart. I utilize the Spoof4Low all the time. The power fold mirrors is a great option as well. I sent a request to have the trailer brake active as an option and they added it with the latest firmware, I couldn’t get it to activate so I am getting in touch with the company.
There are a bunch of options that you do need to have the Tazer connected, but they sell a bypass cable.
MikeSumthin
US
My opinion is that the Tazer is all for show. Yes, the mirrors popping out and the light show are cool however...
Adding additional factory options and going through alot of computer settings became alot more helpful to me.
I did AlfaOBD and then got a Diablo i3... done.4e5e40aab4f5b71b469cfaf1e2319157.jpg
Sent from my SM-G988U1 using Tapatalk
67 StingrayJ
USA, New Mexico, Las cruces.
Ok guys. I read everything in this thread thus far and I have questions. I want the mirrors to fold in automatically when I turn off the truck, then back out when I turn it on. Down the road, I want to install a front camera too, and change tire sizes.
Which one is the best for accomplishing all 3?
Note: I don't like the idea of having something always plugged into the truck. I like my stuff to look Factory!
67 StingrayJ
What is Spoof4Low?
JohnnyMac
SouthWest Washington
2018 1500 Laramie
3.0 EcoBurner
I use this one.
AEM bypass harness
Looks like it's in stock now. Have you looked at the JScan app? It'll do both lighting and tire size. You pay for each VIN. I have both it and AlphaOBD and JScan is by far easier and quicker for simple stuff. Alpha does more though and is for the deep dive. Just my two cents.
