TBCM wiring...
vetteyog
Central PA
Looking for a clearer picture of this page from a wiring diagram, want to add a factory brake controller to my 2012 Ram 1500
When I zoom in on it , it becomes unreadable.
jawzs2
Air Force
South Jersey
You might have all the wiring in place, I did on my 2010, and my son did on his 2012, check out this video
RamDiver
Marlborough, Ontario Canada
2021 DS
When I zoom in on it, it becomes unreadable.
Check the drawing on the PDF from Ian's post here. Although the clarity while zoomed in is marginal, it's much clearer than the drawing you posted.
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
Wiring / connectors should all be there under the dash already. Just need to fight getting the bracket mounted. Kinda plug in, program and play.
vetteyog
vetteyog
Central PA
Thanks for the replies... my truck I only has the 4 wire connector. It does not have the 3 wire connector (or at least I couldn't find it), that's the one I have to wire up myself.
IT is there, there are several YouTube videos that mention that they have trouble finding it.
They liked to Wrap that section of wiring in Electrical Tape
Look for the fattest section & carefully open that section up,
i think you will need to cut the tape
