TGC rear spacer
AustinB
AustinB
Banned
San Diego, Left Coast
So basically when you order a specific part from tgc... They spin a roulette wheel with a bunch of different spacers on it before they ship.
smoothee
St. John's, NL
Took them four attempts to ship me all the components for a 1.25" body lift a few years back...
bassheadhemi
Montreal, Canada
Got my 3/4" tgc poly spacers.
Anyone had issues with them installed at the bottom vs top?
R.L.K.
Bristol , Tn.
Deleted
bassheadhemi
Montreal, Canada
Well all the pictures that I found show them at the bottom...
I guess Ill try top first tomorrow lol
R.L.K.
Bristol , Tn.
Those look like they would have to go on the bottom? The top ones have the long cylinders to go in the hole up top...
AustinB
AustinB
Banned
Only fit on the bottom, the steel ones look different and go up top. The damn guy that answers the phone at tgc couldnt even figure that out.
They should hire me.
IMO
bassheadhemi
Montreal, Canada
Well at the bottom they will go since those are probably no designed for our truck anyways... The 3/4" poly spacer TGC sell for our truck is also used on GM products under the Daystar brand.
Here's picture of the Daystar part KG09103BK
Here's the TGC one
As you can see they look identical and have the same M02684 stamping on them.
jknappen
Kentucky
Austin b
I have your rear 3/4 spacers. So you are saying these have to go on the bottom of the spring and not the top of a 2013??
AustinB
AustinB
Banned
I dont know about the 13, I can only speak for the 15s... But Im also 99% sure theres no difference.
IMO
jknappen
Kentucky
I have been back and forth on weather to put them in or not i set my bils at 2.1 and it looks as if i have a slight nose high look now. Even after puttin new tires on
jknappen
Kentucky
But do the go on the bottom or the top
bassheadhemi
Montreal, Canada
There's no way the poly ones will go on top even if the instructions tell you to put them there. Ive set mine at the bottom with no ill effects
Sent from my SM-N920W8 using Tapatalk
Enscheff
I put mine on the bottom because that's what the instructions said, and I also saw an install post with pics where the guy put them on the bottom. I have seen many discussions here where some people say they need to go on the top, and one person even posted a pic he claims were the instructions his came with that said they go on the top. One guy said he called TGC and they said they go on top and even went so far as to call it stupid to think they go on the bottom.
I put mine on the bottom, and they have been fine so far over 6000+ miles. I have towed and gone off-roading with no problems so far.
Iwishforaname
