The Custom Rear Control Arm Thread
McBroom
Denison Tx
Hemi 6.4L
Um, Ok. All My performance parts were purchased from Matt @Hemi450hp at Moes.
I got in on the Core 4X4 craze very early in the process, before Moes carried them.
But thanks anyways... :Big Laugh:
Uuuuhhhh didn’t know that. [emoji38]
Blue Streak Pearl off-road
JB1
Houston, Texas
Same here, I was working with Spence before Matt said they were selling them, plus I didn’t have to pay sales tax
Booms
Booms
The OG
Ocala
2015 Express
Whipple 5.7 • SmoothBoost!
As a matter of fact, I have the first version of the adjustable panhard bar sitting in My office. It is cool and beefy as hell, but not adjustable on the truck.
I was the first one to receive the Adjustable on the truck panhard bar. Holla ! :Big Laugh:
rwhjr
maryland
What difference will I notice in my truck if I swap crontrol arms and rear sway bar with a 6” lift?
Joshwaa
Lake Worth, FL
2016 CC 4x4 Laramie AirRide
what made you choose a non-adjustable version of everything?
I have no intentions of lifting or lowering. Just figured it would be easier. No nuts and threads to rust. No worrying about joints shifting. Plus just a cleaner look to me.
On a side note anyone know the torque specs for the rear upper, lowers, and panhard? I have seen some specs on forums but they don't specify rear.
JB1
Houston, Texas
Ya I think it’s a great idea, I just didn’t know they offered that
I used the TQ specs from my lift kit instructions
http://bds-suspension.com/instructions/022309-022509.pdf
Joshwaa
Lake Worth, FL
Thanks for that however from trying to take one of the upper control arms off last night and failing I think that it is much more than 120ft/lb. Gonna try again with a breaker bar. I think Spence will make pretty much whatever you ask for as he did for my air ride uppers and color matching my sway bar.
Reactions: JB1
JB1
Houston, Texas
Let us know if you find a definite factory TQ spec
GIJoe2010
No sh*t, there I was . . .
Killeen, TX
Curious question on the Hellwig sway bar: Is that the 7709 (stock height) or the 7883 (for lifted vehicles)?
JB1
Houston, Texas
I have the 7709, it fits all Ram 1500’s (2wd, 4wd, lifted/lowered or stock) since it does not include the endlinks
GIJoe2010
Killeen, TX
Thanks. I just snatched up one from a member here and was curious if there's any difference . . . besides the inclusion of the "lifted"/extended end links (2 or 4 inch) in the 7883 kit.
JB1
Houston, Texas
Your good to go, just use your stock end links.
GIJoe2010
Killeen, TX
Thanks much, I’ll be installing it this weekend
2010 Infantry Vet
Butler pennsylvania
These adj rear control arms are beneficial to 6" lifts so the rear wheel can be put back in its correct position. I noticed on my lifted ram, the rear wheel is pushed more towards the front of the truck. These arms can be extended to move the rear axle more to the bavk of the truck. My only concern with moving the rear axle back, is driveshaft length.
ram1500rsm
Trabuco Canyon, CA
This is what is listed on the torque specs sheet we have aorund for the Upper and Lower control arms
Isn't 200ft/lbs a bit too much ? ********
I put 114ft/lbs on my rear trackbar per a post i found from somebody suggesting that.
In my JK, the trackbars were set at 125ft/lbs, and the bolt was 21mm, which if i remember is the same in the RAM 1500 ?
https://www.ramforum.com/posts/802220/
Joshwaa
Lake Worth, FL
I put upper and lowers to 170ft/lbs nothing has broke yet so guess it is ok?
