Thinking of making the switch to 2500 6.4
nlambert182
Huntsville, AL
The main 10K pound thing I'm aware of has to do with the GVWR of the truck not the trailer. In Oregon they even distinguish some laws for chaining up in the mountains based on that which is pretty crazy IMO. A 2500 and 3500 are extremely similar trucks and, according to the law, the 3500 must chain up while the 2500 is okay with just traction devices. I've also heard of HOAs banning "commercial" vehicles which a 3500 is so guys just get emblems from a 2500 to make the blue hair HOA boss happy. Aside from the emblems, 2500s and 3500s are really the same from the outside.
Our friends live in one of those HOA neighborhoods... He has a 3500 but has magnets on the doors and no service box. He just pops the magnets off when he comes home and they're ok with it. Kind of a silly rule to me..
Docwagon1776
Midwest
It's going to be tough to find any 2500/3500 that's worth salt under $25k unfortunately. They're out there, sure... but either worn out or chock full of miles.
The 6 speeds in the 2500 gassers do "seem" to have their share of issues from what I read, but take what I say with a grain of salt because I know very little on the gassers. They didn't suit my needs so for 3/4T and up I've been in a diesel since 2010.
Even without considering reliability, the feel of driving is night and day. In the 1500 day to day it isn't such a noticeable difference. The 2500, much more so. Drive one back to back and it's very very noticeable.
tbird71
Lake Placid, FL
Don't buy a 2500 6 speed or a worn out hi mile POS trying to stay under 25K is all I'll say. Or spend 25K on a worthless used up one and another 15K once it goes in the shop (and odds are it likely WILL). I would think you could land a good 3500 8 speed for around 40K. (being realistic) Me it'd be easier to pony up then go to the repair shop. Step up to the plate or quit the heavy construction business...you cant have BOTH)
tbird71
Lake Placid, FL
OK here;s a 19 3500 6.4 8 speed BIG HORN CREW with 5oK one owner miles for 36,988 in Orlando fl
Hell at THAT cheap price you can ship it! They've had it for 122 days, offer em 35000 OTD bet they take it
What're you waitin for?
Overlander
Oregon
2021 75th Aniv Build #0006
The main 10K pound thing I'm aware of has to do with the GVWR of the truck not the trailer. In Oregon they even distinguish some laws for chaining up ithe mountains based on that which is pretty crazy IMO. A 2500 and 3500 are extremely similar trucks and, according to the law, the 3500 must
If you look at ORS 815.145, both the 2500 and 3500 are required to use chains as their empty weight is over 6,500 lbs. This is what you will be cited for. The ODOT signage and website is based upon an administrative rule 734-017-0015. This applies to commercial operators. What's even more confusing, is the signage states GVW (actual weight) while the website states GVWR (rated weight).
Regardless, if you stay out of the ditch with either my guess is you'll be fine. It's when you block a road or cause an accident that the details get picked apart. And even with that, you could still always be cited with driving at a speed unsafe for the conditions (ORS 811.100) or worse Careless 811.135 or Reckless 811.140. So even if exempt, that doesn't mean you're completely free to roll sans chains.
mtofell
Strange... I never knew anything about the 6500# thing. I've just seen the signs and info on the Tripcheck page: https://www.tripcheck.com/Pages/Chain-Law#:~:text=You must use chains if,GVW whether towing or not.
Snoopy
NE Ga
That is what I am wanting to do is upgrade from my 1500 to a 2500 6.4. You wont gain anything with a 3500 unless you get dual rear wheels on it.
Overlander
Oregon
If you scroll down to the bottom of that link you'll see the ORS (without it stating that it's the ORS) and the 6,500 lbs requirement.
ODOT only cares about it's administrative rules, which are enforceable to motor carriers, but are not actual laws in the state of Oregon. So they put up these signs and most people take them as the law. If you're not in commercial service, the citation would be for ORS 815.140. Though I'm not sure that many troopers or deputies are that well versed.
I doubt 815.140 citations are ever issued for 2500s or 3500s unless running summer tires or 2wd. My guess is those violations are used for the semi driver who fails to chain up and gets stuck.
And back to the original point, I wouldn't hesitate to roll a 3500 with traction tires (and 4wd) any more than I worry about running my PW over its GVWR (but under other 2500s GVWR). I cross the cascades 50-60 times per year and cannot remember seeing 3/4T or 1T trucks with chains. The only chains I see are on FWD passenger cars and commercial vehicles (>26,000 lbs).
And, while not on topic, airing down should be the number one tool, not chains. Even at 9,000 lbs I run 35psi for good traction white roads and 20-25 for more naughty stuff. Airing back up, of course, when conditions change. 35 may seem low, but if you look at a tire inflation chart E rated tires are usually good for 2,300 lbs at that pressure. Obviously need to know your axle weights and do the math for what is right for your load and conditions.
mtofell
I started running 4-season (not all-season) tires since they have the snowflake rating. I don't actually feel they are much or any better in the snow/ice than other tires but I don't want to get in a wreck going over Mt. Hood and not have the "right" equipment. I used to swap tires 2X a year but that was kind of a PITA. Great info... thanks for sharing.
magz
New Ulm MN
Hemi 5.7 E-Torque
I have a 2018 6.4 2500. Love it for towing.
2Tallguy
San Diego
5.9 diesel
I agree 4.10 gears are preferable but you're extremely unlikely find one. For whatever reason, 90%+ of the truck had the 3.73 gears and it really isn't that much of a difference. Watch out of tranny problems for sure. As time goes on the 66rfe isn't going to go down as a very reliable tranny... in fact, it's looking to be one of the more problematic ones.
I'll preface my experience by saying I have a Lifetime Maxcare warranty so I haven't really been monetarily hurt but my truck has had quite a few problems - first tranny blew @ 38K miles zero load - sitting in traffic on the freeway, went to accelerate and had nothing. That rebuild failed again at 90K miles and I'm holding steady at 130K. My engine blew at 110K due to some main/master (??) bearing problem and I got a new crate engine.
Overall, I love my truck but would NEVER own it without a warranty in place. 5/6K per tranny rebuild, 12K+ for an engine? No thanks. My daily driver is a 2008 Honda Odyssey with 130K miles that has been totally trouble free for 15+ years. I'd be daily driving my Ram (with warranty) except I moved to Maui with my Honda and left the truck on the mainland to use when I'm there - roughly 25% mainland/75% Hawaii split. I guess my advice is to go into the Ram with an open mind and checkbook as things do come up on these trucks.
I'll be in Maui on 3/4. On the Big Island Ram diesels were the most prevalent,next Ford and very few Duramax's.
olyelr
Kewadin MI
The 3500 single rear wheel will have more payload. They also have leaf spring suspension in the rear apposed to the inboard coil springs on the 2500, so towing heavy is much better with them.
17Ramguy78
Delaware
Appreciate it everyone
I’m trying like hell to find one with the 4:10 gears.. as said it seems almost impossible.
Its a frustrating thing.. I’m trying to start my own small construction business this year and need a bigger more capable truck( I’m coming from a tundra) and I really don’t want to take on a big payment and get ahead of myself.( or buy a *************) Just need something to get the ball rolling.
Proving to be quite difficult, and I am a bit suprised at the lack of abilities of some of these older HD trucks of all makes.
Please take this with a grain of salt. If you are looking to start your business on the low end does your truck necessarily have to be a Ram? I would look for a tried and true workhorse and I see tons of super duties pulling trailers. Mind you I'm not endorsing Ford by no means just going by what I see. If it must be a Ram then do your research first. I have the 66rfe tranny in my 17 but I have not really tested it towing, that will come spring . I do hear the 8 speed is the way to go 19s' and up.
62Blazer
Midwest
What conditions and routes are you going to be towing? In my opinion there is a big difference between towing 200 miles at a time on the freeway going 70 mph, versus towing 5 miles through town or on 55 mph roads. My guess is you are going short distances and very little high speed freeway time. There is a group of guys I tow with (pulling multiple trailers to sites). Most of the time it's fairly local and you are pulling maybe 10-15 miles at max and maybe up to 55 mph for short distances. We don't even bother with WDH hitches and airing tires up further ect....for those trips. On the other hand we do a handful of 100-200 mile trips a year on the freeway in which we will hook up WDH, run higher air pressures, etc....
In any case, a 2500 6.4 truck will do fine either way. I also wouldn't be scared of the 6 speed. Sure, while there are dozens of people who jump on here and complain about the transmission there are also literally millions of these trucks on the road. And many regularly pulling trailers. A few dozen divided by millions of trucks is only a fraction of a % with problems. I personally know many people with 6.4 6 speed 2500 trucks and only 1 has had any trans problems.
N
Northwoods22
Minnesota
Not at all. Just seemed like best bang for the buck. My first pick would be a GM.. but I test drove a 2500 with the 6.4 and was impressed. In the HD market I am not biased at all, I know little about them. Open as can be
N
Northwoods22
Minnesota
Flat rural or in town 10-15 miles loaded . I appreciate the advice. Most internet towing info seems to come from long distance towing big campers. WD hitch and all that is incredibly impractical for construction, have never seen it once.
N
Northwoods22
Minnesota
I like it.. and I know. But sometimes can be easier said then done. Need to be a bit more comfortable in my situation here before I step up big ( for me) . I refuse to be the guy who buys a big fancy new truck because he sold a few jobs and then the phone stops ringing..
HEMIMANN
Minneapolis, MN
2017 2500 Laramie Crew Cab
I have a 2017 Ram 2500 Crew Cab 4x4 with Hemi 6.4L and 6 sp trans. No issues to date with 55,000 miles.
I'm vigilant about maintenance, however. I change lubricants no later than manual recommends, usually before, and only with quality lubricants, and by myself so I know it's done right. Never a quickie lube or dealership.
I don't haul heavy routinely, but I do run 7,000 lb trailerloads app. a dozen times a year. Which is why I got the 3/4 ton. Perfect setup for me. Well, I might have gone with 4.10 gear axle, but would have had to wait for special order because std axle was 3.73. It does alright, if you take it easy and only run with tow shift program and 4th gear tops.
62Blazer
Midwest
In those conditions I think a 6.4 truck would do great and has plenty of power. Agree that WDH is a pain in those type of conditions. Worked on farms and a construction company for years back in the day pulling trailers everyday and never used WDH or did anything else special. Had a cousin that pulled a dual tandem gooseneck with a backhoe on it several times a week with a 3/4 ton truck with a 190 HP V-8 (standard power back in the 80's) and it did fine. The trailer and backhoe were at least 15,000 lbs. 99% of the driving was on rural roads within a 10 mile radius and rarely got up to 55 mph.
firefox9
