Those who have had Linex sprayed after buying their truck...
lobsterbake
Atlanta, GA
Cummins Turbo Diesel 6.7
Hello,
My 2500 CTD truck is on order and I didn't get the Linex from the factory option. I want a local dealer to do it as it will have the UV protection so it wont fade as my understanding is that the factory option doesn't have this. I wish Ram didn't put the bed rail protectors on from the factory - those that have had Linex sprayed after the fact - did the Linex dealer have to take them off to get the Linex coverage high enough on the bed sides? Any issues with them being damaged if they took them off when they put them back on? I don't want the rails or the paint on the vehicle damaged if they take this off so curious what others who have gotten Linex sprayed after buying the truck have experienced.
Thanks,
Mark
BlkZrx
northeast IN
2016 2500 SLT Std. cab
They did mine just fine. Bed rails were clean. Had one tiny drop on outside of bed they cleaned up. I think they mask them well..
Sent from my LG-K540 using Tapatalk
Fearfact
Mine is linex’d and the factory caps are there. They spray the underside of the rails and didn’t remove them, if they’re removed and sprayed the holes would be filled and/partially filled making reinstalling them difficult and they wouldn’t sit right anyway. I wish they didn’t put those caps on from the factory and that the rail wasn’t riddled with holes for them-making us stuck with it. I’d rather linex the rails and top inch or two of the exterior bedside but cant with this setup
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
I had mine rhino liner and its holding up very well. I'm really happy with it so far and its been on since last summer. They don' remove the bed caps as if you do they are typically damaged. Rhino or linex are both good. You will be happy
17CrewCab1500
I saw a work truck that had them removed and had liner sprayed where they where. but yeah there where square holes everywhere.
The should mask to the plastic. I bet you can't wait for your truck to come!
bigkyle72
Sacramento, CA
2004.5 and 2017
5.9 and 6.7
this was my experience as well
14RAM4X4
Sweating somewhere in South Texas
2015 RAM 2500 4x4
6.4L Hemi
Mine was linex'd from the dealer when I picked up my truck. The only issue I had was the the drain plugs don't fit back in the holes. It was a pain in he ass to get them in looking bowed and they kept popping out. So I just threw them away.
I have a tonneau cover that keeps most of the dust and rain out. If I didn't always have canvas folding chairs and a canopy back there it wouldn't matter much. After it rains good (not too often in S. TX) I just have to remember to take everything out to dry out.
