Those wire broke turbo actuator will I need calibration??
Brandon-w
Yukon
2015 Ram 1500
No should be good. You'd only need to recalibrate if you replaced that actuator it's self. Essentially all you did was disconnect the plug the hard way :893karatesmiley-thu
nlambert182
Huntsville, AL
No recal needed, as Brandon said. Fix the wiring and you should be good to go.
