Thoughts? What would you pay?
Purple 92 SS
5.2 magnum
Hello all. I'm new here so if im violating anything or posting in the wrong area please feel free to fix it or correct me.
I've got an opertunity to buy a 2nd Gen Ram. The photos will say vastly more than i can about the truck. it is a 4x2. I've never owned a ram, as im primarily a camaro guy, but dodge / mopar has always had a place in my life as as a kid i had many pentastar vehicles. That being said, here's the basics of the truck.
According to the door frame tag it was built in 12/95. It would make it a 1996 Dodge Ram SLT Laramie Standard Cab short bed 4x2. Red / grey 2 tone, with tristar rims. Grey interior. Needs a good bit of TLC. No known rust i can speak of. Has the 5.2 ltr magnum motor, and is an automatic.
Known Issues :
Dash cap needs replaced. badly. Carpet badly stained, may need replaced. Driver side seat ripped, foam compressed / needs replaced as well. all seats actually have ciggaret stains, and other stains, as well as burn holes. Missing ash tray, may need dash bezel as its cracked. factory radio, volume *** not great. Over head console, broke off ceiling, but glued back to its screw mounts so can be removed, but needs replaced with un-craked one. The back window is split sliding, but the latch is broke off, needs replaced. AC works, but under driving and throttle would go to dash defrost only instead of front vents (from what i read while lurking its the "wild vents" situation) Also the one time i drove it, the passenger window was sticky at first trying to put it down, but it did go down without issue afterwards. Probably from non-usage.
Exterior. Front grille, held on with wire ties. looks that all mounts were broken. Passenger side marker lamp / headlamp cracked broken. All headlights yellowed. Front bumper / passenger side slooks like it took a small hit and bent it back. Paint is not great, obviously. Mostly good, but cracking / clearcoat flaking...
Drivetrain issues arenot known to have any at this time. All workwell, heat, air, motor is strong, accellerates well, no slippage from tranny no issues known as i said. Exhaust may be the one issue, as it is aftermarket and very loud, and almost sounds like its failing but i cant be sure till i get under it and inspect it. Truck has 136,*** miles on it.
so my basic questions are 1, what would you pay for this truck? private party. My co-worker is the owner, and he's wanting to sell it to me, and states he'll even finance it with no interest per month.. (dont have a lot of money here lol)
2.) How hard is it to put later model seats in it? if i were to swap it with say 02-12 seats? what all is different from 2nd to 3rd to 4th gens seat mount wise? I have read some of the threads here, but none are full write ups, with photos, of mounts, and brackets being reused / remade or side by side write ups.
3.) Dash cover, how hard are they to replace, and how much should i be expecting to spend on a new cover?
4.) What major things should i look for before i were to buy? what could be a big issue? what could be a costly repair with these trucks?
5.) also any other things you care to suggest/ comment on?
Here's the pics, i look forward to hearing what you all think / have to say. I've lurked the Pic page (entire thread) and ya'll seem to be a great group here. Thanks.
-Steve
RamV10
Western Central NV
V10
What are they asking for it? How many miles?
In Aug of 2011 I bought a 99 Ram 2500 QC 4x4 V10/5 Speed 72,000 miles. Needed tires, inner fender well rear. body has dings & paint not the best. interior was good cracked dash common on all 2nd Gens. with a GemTop camper shell & carpet kit. FOR $5500.
Since I had to replace ABS sensor rear, rear axle seal, thermostat & gasket, washer bottle, tires, Of course regular oil filters etc.
So does this give your any ideas? It runs perfect, I use to to tow my trailers. empty gas mileage is 11-12 mpg.
P
Purple 92 SS
5.2 magnum
kinda.. i think your saying it is a good deal. and that i should do it.. i could be wrong though..
Bigboy0207
Fl
I have a 99 with 89,000 miles on it.. Needs a paints job a new windshield front bumper and a new dash. I'm selling it in fl for 1200 just to give u a ball park
P
Purple 92 SS
5.2 magnum
so its fairly good price then. cause its close to your price, but youve got less miles...
thanks.
dapepper9
Iowa/Nebraska Border
5.9L V8
I'd offer bout 1300 and use what you saved to get the dash or grille fixed. AmericanDashCaps has covers made of the same material to go over the grill or the bezel and it looks factory and is easier than completely taking apart the dash to get the original out. Thats what I did and it looks great.
P
Purple 92 SS
5.2 magnum
thansk for the tip about american dash caps.. the price was pretty fixed.. so i ended up bringing her home on firday night.. heres teh updated pics / slideshow, after i cleaned her up a bit.
Passenger Side :
Driver side :
Interior :
the rest and more detailed pictures can be seen in the slideshow here :
Took Possession 9-1-13 Slideshow by Purple_92_SS | Photobucket
fla crkr 1 ton
Palm Harbor Fla.
5.9 [360]
Dash covers only work on a dash that ain't completely roached [missing big chunks] L.M.C. Trucks carry's a pretty good selection of parts for 2nd gen rams and junk yards are full of them. Try Craig's list for people parting out these 2nd gens we have always got several here. most of the interior, body parts off 1500, 2500, 3500 are interchangeable. Not a bad truck you have with a little TLC it'll be nice. I bought one last year 2001 one owner 4x4 119k miles [bad dash after I purchased it] for 5800$ [had a 98 cummins one ton dually that got totaled] this replaced it [it don't fill my duallys shoes] but I like it! Before [when I got it Sept 2012] and after 2 1/2 lift, wheels tires, exhaust it's taken a year to do this.
