Bear_Gibson
- Feb 10, 2016
- 195
- 28
- Location
- Cape Girardeau, MO
- 1999
- 5.9 magnum
I would put high temp rtv in the bolt hole and thread in the bolt. I don't know if Teflon tape would work on a straight bolt. As far as my truck goes it use to take off quite nicely from a stop, and anytime you wanted more power it was there. Now when you mash the gas it boggs till the engine builds some rpms. Like a turbo lag. So it acts like a tiny engine till after 2000 and then you get normal power. I also have a tune that advances the timing and helps to give it even more low end torque than stock. Now it feels like you're towing a huge trailer every time you take off.
Sent from my E6910 using Tapatalk
