Timing the order...
Justin Matthews
Wylie
EcoDiesel
I am pre-approved for a loan ... now I just need to place my order for a 2021 longhorn limited. Trying to time the order. What’s expected turn around time? Any advantage to pushing out for a December deliver versus a November delivery?
Jm91rs
Cincninati
Not sure how it will compare to a Laramie, but I ordered on 8/24 and received on 10/2. If you order now and the timing is the same it'll be built mid November. As far as advantages, there aren't a ton of rebates right now on 2021. The longer you wait the more likely there will be more rebates.
BNeal
Celina, TX
2021 Limited
This would be my advice as well if you are after incentives. I ordered my '21 in mid-July and took delivery September 15th. There were no incentives available at the time. My guess is by February, you should start seeing some factory rebates.
