Tire And Wheel Question
Kapt
3L
How wide are the factory chrome clad 20" wheels? Will a 35/12.50/20 tire work on them? Just checking options. No real plans yet here
UnsatFC
Active duty NAVY
New Jersey
What year do you have? They are either 20x8 or 20x9. Both should be able to fit a 35x12.50 tire on them.
Kapt
Kapt
3L
2016 Laramie Ecodiesel
Kapt
Kapt
3L
Just a 35/12.50/20. Like I said. No plans yet, just checking options
UnsatFC
Active duty NAVY
New Jersey
Ok. I'm looking into a set of 315/70R17's BFG's myself. I will need new rims since my stock 17's are not wide enough. Just have not pulled the trigger yet.
Kapt
Kapt
3L
Anyone want to reply that can answer my question? I would appreciate it :)
Solid State
2011 Bighorn
I have 35x12.5x20 toyo mts on my factory 20x9's
Kapt
Kapt
3L
That's what I needed to know. Thank you!!! Looks great!!!
quietpeen
2021 TRX
Hellcat
They should be 20x9 and many people have run 35x12.5x20 on stock 20's. If you don't already know you most likely will need 1/4" wheel spacers in the front to keep the tire from rubbing the uca's
Kapt
Kapt
3L
Even with a leveling kit?
Csanders1992
Rubbing the ucas is a problem with the wheel offset/back spacing. Not lift amount. The 1/4" spacers will move the wheel away from your suspension creating more clearance
quietpeen
2021 TRX
Hellcat
this....two different things
Kapt
Kapt
3L
Thanks
Jayc057
Not to thread Jack at all but I think this may be a relevant question anyways. Are you running wheel spacers on front and back? Your set up looks perfect I'd love to have the same stance.
I didn't see the last couple replies that sort of answered the questions.
