Tire clearance question
Grizzwald
I have a 2016 ram 1500 tradesman with a factory tire size of 265/70/17 and want to go larger like a 285/70/17 but I have been told I will rub anyone out there know if this is possible to run with no rub issue? This is a stock setup and plan to keep it like that no lift or level kit
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
That's about an inch taller, could rub, and they are a tad wider.
Be tight.
G
Grizzwald
Tire shop said ask around and see they said 275/60/17 would be fine but I wanted the taller option of course
DannyMK2
Long Island, NY
2015 Power Wagon
285/70/17 is a 33" tire. these trucks with stock 20's have 33" tires. height is not an issue. neither is width. some 295's rub, some dont. you should be fine with a 285 tire. the rebel comes from the factory with 285/70/17 on it as well.
G
Grizzwald
But the rebel has a different front end I think where I worry is the inner plastic liner that it may run on
G
Grizzwald
Anyone else want to weigh in on this question
Rken1288
I think you will be fine. I have 275 70 R17, but I'm sure 285's would have fit stock. (I chose 275's because I drive a ton of highway miles)
With no lift:
With Bilsteins set at 2.1:
G
Grizzwald
How do those bilsteins ride and did you notice a massive change such as needing an alignment my truck will go off-road quite a bit don't want massive ride issues
G
Grizzwald
And dealer said 285/70/17 will run just can't seem to find out where
G
Grizzwald
*rub
Rken1288
The Bilsteins ride and drive amazingly. I live off dirt roads and the ride has greatly improved. I went with the 2.1" setting and the truck was immediately aligned after the install and tracks straight down the road. Very happy overall
G
Grizzwald
Where did you order them from?
