Tire Pressure Monitor System
82Crew
North of St. Louis
318 Magnum, 6.7 Cummins
Does anyone know how I can turn this stupid thing off or at least program it with lower tire pressures? The truck wants 75 front 80 rear and no matter what I do I cannot make it go into light load, also the left side reads backwards. It tells me the LR in the LF on the display so even if I got it in light load this would still cause the light to come on. I would like to be able to program it to around 40 psi for all 4
07MegaCabRam
Chandler, Arizona
6.7L CTD
Nope. Can't do it. You used to, but Ram removed that feature. Thankfully I was able to adjust mine before they changed it with the Witech2 update.
40PSI is for better ride I'd assume, but that is REALLY low for solid front axle trucks. You're asking for cuffed tires and a possible wobble.
82Crew
82Crew
North of St. Louis
I have the front at 65 and rear at 50 so I wanted to turn the pressure on the sensors down to 40 because if they got that low I would want to know about it
82Crew
82Crew
North of St. Louis
I'll see if I can get the pin and do it myself
goonbash
Banned
2016 2500 Longhorn Limited Megacab
cummins
Old thread but I just had Nando at Elite Auto in Costa Mesa California reprogram mine. Pricey but succesful. 2016 ram 2500.
