Tire pressure sensor damaged?
Gamester
Hey guys,
So I got me a set of new tires and they are great, but for some reason, my dash keeps saying I have a low pressure in the right front tire regardless of how much pressure is actually in the tire. I set them all to 40 PSI today and that one tire is still showing 37PSI. Could the sensor have been damaged when they changed the tires? How can I check/test the tire's sensor? I don't even know where the actual sensors are for these.
-Thanks
stimpy433
IOWA
Do what I did, move it from the front to the back.... if the problem follows, it's a bad sensor. Most tire shops have a scanner that will read the status of the sensor, maybe they can try and reset it.
Gamester
Gamester
Good info, where are they located exactly and how easy are they the remove, do they just unplug or unscrew or something?
stimpy433
IOWA
They are inside the tire attached to the end of the valve stem. Just swap the wheel assembly front to back.
Gamester
Gamester
So, if i it all inside the tire, how does it send the sensor signal to the PCM? Is there some kind of short range wireless receiver near each wheel or something?
stimpy433
IOWA
Here's a diagram of basically how it works.
Gamester
Gamester
Hmm, started working again all the sudden; hope it stays that way :)
Thanks
stimpy433
IOWA
Thanks
Mine work for a while, then all the sudden 1 or 2 of them will error "--" out. It's kind of random, but seems like mine do it when I drive longer distances. The short trip to my work won't set them off, but driving across town will do it.
