Guinea
So my 2014 1500 currently has 4 Cooper tires on it, and before this it had Michelin Tires (mightve misspelled the name). I've been having this issue where even though all 4 are at the manufacturer specified 39 psi cold, the middle of the rear tires always wears out and they're once again almost bald. I've tried lowering this latest set to 35 psi in the rear, still 39 in the front, but it doesn't seem to change the rear tires wearing down quickly in the middle. Is this an overinflation issue or something deeper? Should I only have them at 39psi when under an almost full load? If so what should I keep them at? And is there a way in the computer to set the new tire pressure lower so the TPMS light doesn't come on everytime I start the vehicle? Thanks in advance for your help!
