tire question
big_red06
2014 Bighorn
will LT305/55R20 work at stock height with no level and factory wheels without rubbing ? I want a little larger more aggressive looking tire but im happy with wheels for now and a level is not in the budget at the moment any input will be appreciated
BOWERSFJ
Uniontown OH
Proly gonna rub with 305's . . . Depends on how aggresive the sidewall tread is also . . . I'd stick with 295's . . . Not sure how your budget works, but a level can be had for as little as $75 for a Hell bent Steel, up to $200 for Bilsteins . . . You're gonna need a alignment either way . . . Tires like yours are gonna set you back $1000 . . . Wait a couple more paychecks, and get the level and 295/60R20's . . . Just my opinion
Wandell
Cummins 6.7
It's an extremely tight fit because of the combination of tire width and the backspacing of the stock wheels. It's so close that some 305/55-20/33x12.50 tires will rub the control arms slightly at full steering lock and some won't. It's not a huge issue as they are just touching at full steering lock. You can either install a small wheel spacer or just don't turn the steering wheel all the way to lock.
