Tire size change alfaOBD
Firetruck41
Washington State
2500 Mega Cab Hemi 5.7
another question:
my 285/75-18 listed size is 35.1"
I have measured my tire height with the level on top of the tire method. Front tires measure 33.5", rear tires measure 33.75"
which of the 2 measured heights should I convert to mm and use for the input?
thanks
The manufacturer of my tire has a "revolutions per mile" for my tire, so I used that and calculated a mile divided by the revolutions, to get circumference, then converted to millimeters, I think I ended up with 2625 mm... Anyway, it seemed to work, speedo seems accurate. My tire is Yokohama AT G015 in size 285/75/17
kylant
Bend
Cummins
i must be missing something because my calculations don't work
593 revs per mile
5280 feet in a mile.
5280/593=8.9 feet per rev
8.9x12"=106.8"
106.8" per rev... now what?
AFMoulton
Nuevo Mexico
Anyone done 295/70R18? I keep coming up with 2734 but it’s still 2 MPH fast, I’ve backed off to 2724 still 2 MPH fast......not sure where to go from here.
2018 2500 6.4 4x4 4.10 Amsoil SS 0w-40, Softopper
Black Rhino Arsenal 18x9 +12mm
Cooper St MAXX LT295/70R18
66RFE/68RFE Thermo Bypass Valve Install
2016 Durango 5.7 AWD 3.07 Redline 5W-30 RP 10-48
1996 Nissan Altima 2.4 Amsoil SS 5W-30
Jimmy07
Are you using what a tire calculator converts that size to in inches, or what the actual diameter is as it sits on your truck? Go with the actual diameter as it is on your truck, at the tire pressure you’re gonna be running. The tire calculator can vary by as much as an inch between manufacturers.
Jimmy07
593 revs per mile
8.9x12"=106.8"
I’d say don’t worry about what the tire says, or what the manufacturer claims. If you’re dialed in at 2689, that’s what matters. 2689mm/25.4=105.87 inches actually being covered in one revolution. If the speedometer is matching gps, you’re all set.
Firetruck41
Washington State
593 revs per mile
8.9x12"=106.8"
Convert those inches to millimeters and you are there!
EDIT: 106.8" = 2713 mm, but as mentioned above, if your settings have the speedo/odo working accurately, you don't need to change anything.
Kenepo17ram
Brooksville, FL
2019 ram 1500 classic change my tire size to 2520, my tires are 33x12.5x20 measure at truck is 31 5/8 which is 31.625 x 25.4 = 803, 803 x 3.14 = 2521, i change it with alfaobd it took the change but it never give all kind of lights in the dash, i double check it says it 2520 still no crazy lights on dash. Os mandatory i get them after tire size change?
Sent from my GM1915 using Tapatalk
Firetruck41
Washington State
2520 vs 2521, is less than you could accurately measure, it is 0.03%. your speedo has a lot less accuracy than that, so you have nothing to worry about.
Kenepo17ram
Brooksville, FL
Actually in my way home from work speedy was accurate with gps, before speedy was showing about 3 mph less than gps now all is good
Digitalage
USA
Cummings 6.7
I guess I need information on this bypass cable , can't get into the ABS module
Digitalage
USA
Cummings 6.7
Okay thank you, now I just have to figure out why abs won't let me in I changed my tire size and now my dashboard screwed
Digitalage
USA
Cummings 6.7
Well I got in and run everything as he stated and I'm back in business, thank you very much..
jimh4662
South of Pennsylvania
2019 RAM Laramie Longhorn C.C. Delmonico Red PearlCoat
Anyone change Navagation input to work while driving? 2019 1500 DT. Thanks in advance
rroche1982
Baton Rouge
EcoDiesel
I adjusted my tire size and didnt get any codes, is that right? It says I have the right size programmed in the BCM
jjs3788
maryland
Is there anyone in Maryland who has done this and is confident in using the Alpha ?
ChloeBrooks
