Tire size
jklberry
MI
I have a stock 2023 ram 1500 bighorn/lonestar, 5.7 hemi. The stock oem tires on it are 275 55r20. My question is can I get away with a 275 60r20 tire without any rubbing or issues? Ive read mixed stuff. Some saying it may rub or it will, to others saying no it wont.
Thanks for the input.
olyelr
Kewadin MI
Im sure it will be fine.
The tires are only an inch taller…so really only a half inch closer to the fenders. Turn the tires in all directions and see what kind of clearance you have…if there is a half inch or more you should be good.
J
jklberry
MI
I do assume it will throw off the speedometer if I go the next size up correct?
Namelama
So. Cal.
3.0 SST
I did the exact thing with tire size, but I replaced front with Bilstein's 5100, and have had no problem at all. The only reason for the Bilstein was to level the truck, did not need them for this tire size switch.
jklberry is right on point, the only difference is that the speedometer is actually off by 1.6 mph, which will also affect odometer, I would guess.
Govtman
Oklahoma
My 19 came with 275/60/20s so 33" tire. I now run 275/65/20 a 34" tire with no issues
olyelr
Kewadin MI
The speed difference is not constant…its a percentage off. So the faster you go, the more its off.
olyelr
Kewadin MI
Yep. I may just stay stock size when i swap out the factory tires just so i dont have to mess with that…although its not a big deal to do it.
