tires after leveling kit
bigbadram1500
Springfield, IL
I think 33's would be fine. I run 33's on an 05 4x4 stock height, so with your leveling, it should be fine, but 34's could prolly work too as stated above.
Oefootball_70
OLATHE
I run a 295/70/18 (34 inch) with a 6 inch lift (2wd)
I could fit ALMOST a 37, but I liked smaller tires when I bought this set, planning on going larger next set.
For your set up I would look at something similar to mine, bellow is someone with the 3 inch Roughcountry coil lift and the same tires as mine. Looks great IMO.
quietpeen
2021 TRX
Hellcat
just for visual reference the rams with the stock 20's come with 33" tires
Oefootball_70
OLATHE
Not the 2wds right? I can with 17's but I had a 28 or 29 inch tire.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
some 2wds came with 'em. Some didn't........but I thought they came with 31s on 17s?
Oefootball_70
OLATHE
Again that was 5 years ago. I don't look like AS big of a goof ball.
garner
Harker Heights, TX
17s have 31" tires and the 20s(on 2wd and 4wd) have 33" tires. The stock wheels in your pic are 17s I believe so 31"
Mad Cow
Anchorage, AK
Cummins 6.7
Yeah I would go 34's as the largest tire. You can get some pretty good looking 33's also for a little cheaper.
ap577
Camp Pendleton, CA
Was this the 3" Lift kit from rough country? I like the look, I want more info because my truck literally looks except the same besides the wheels Haha.
Do you have the Username for who's truck this is?
Debating on how much of a lift I want to do
Oefootball_70
OLATHE
Not a member on this forum. His suspension is a rough country three inch coil lift and 1 inch rear lowering shackle. With 295/70/18 Nitto terra grapplers.
I've always stuck with the 33's when I level. They look good and I would't go any smaller for sure
glsander
