Tires and Wheels - Thoughts
NPietracupa
Hey folks. A new Ram owner from Manitoba, Canada here.
Just trying to spice up the dodge a bit, and I thought I would start with a new set of wheels and tires, but am just wanting a confirmation or any tips and suggestions that anyone would like to pass along. Any and all information passed on would be awesome.
What I got: 2015 Dodge Ram 1500 Sport Hemi 5.7 (Orange)
What I want: Wheels - 4x Fuel Vapor 20x9 (offset to be determined)
Tires - 4x Toyo Open Country MT 35/12.5/20R
Stock style stance levelling kit - front paired with a rear end kit to give it at 2-3 inch overall lift because I do a lot of heavy hauling.
My question to you guys is: Do you think there would be any concern for rubbing anywhere? Should I get the wheels with an offset to avoid this? If so, what should it be? Should I just get spacers? What is everyone's thoughts on the tires sticking out, compared to the standard even. (wanting a mean look for the orange and black concept)
Look forward to hearing from you,
Nick
HemiPower36
CA
2014 Ram 1500 Laramie 4x4 3.92 8-speed
All I have on my truck are the Bil 5100 set at 2.1" and it isn't exactly level, but pretty darn close. I am running 20" fuel wheels and 35x12.5 toyo MT. I don't have any rubbing at all. I do have a custom steel bumper that does free up some wiggle room.
However, you mentioned a "rear end kit," which, I am assuming are just blocks? So, you can prob go 2.8" like a lot of people on RF and have no issues with rubbing at all.
I like when the tires stick out a little, but not an obvious over the top look. Mine don't stick out at all. I don't want dirt, armor all, etc., spraying the crap out of my truck.
Csanders1992
If you haul heavy I would either do bilsteins at 2.1 with air bags in the back, or 2.8 with a 3/4" inch rear spacer and air bags
MADDOG
Living in a Firepit
With 12.50's you will want some wheels with a 12 to 18mm offset to clear the inside.
As far as a level kit, 2" might get you want you need to clear a 35 but it's gonna be damn tight.
Jerry1984
Meridian, Idaho
Here is what a 12.5 wide tire with a 9 inch wide wheel with -13 offset looks like. I would say if you want an aggressive stance go with a 0 or negative offset. I only have a 2 inch level and could fit 35s. Only have 33s now and there is room. Will be upsizing tires when it comes time to buy.
N
NPietracupa
What are you running for an offset, if any?
N
NPietracupa
Would you suggest just going 33, instead of the 35?
