Tires for 2020 Ram 1500 stock
piemontes
NY
Hi there. About to get new Falkens for my stock 2020 1500.
Stocks are 275/55r20
I know I can go safely w/ 285/55r20 's.
Does anyone know if 285/60 r 20's can fit (and w/out rubbing anywhere)?
Did anyone fit 285/60 r20 's, even from a different tire brand?
Please advice if possible. Thank you in advance.
CanuckRam1313
Ontario Canada
2023 Warlock
I had BFG KO2's on my stock suspension in my 19' sized at LT285/65R20 and there was no rubbing.
It was close though.
I then upgraded to 5100's all around, reused the stock springs and set the fronts to 2.1" raised.
I now run LT295/65R20 (equivalent to 35's) Michelin Defender LTX M/S for my summer set up on my 23'.
Ramsteen23
MA
Assuming you're talking about the Falken Wildpeak A/T4W?
If so, looks like there's only a 1" difference in the OD between the two sizes you mentioned (32.6 vs. 33.6) and the SW is pretty much the same so both should fit without any rubbing.
I went with LT295/55/22 Toyo OC AT3 tires on my 23 1500 but I added a 2" lift/level to ensure they would fit with no issues..they are 35/12.2. There was only very slight rubbing at full crank before I added the lift.
P
piemontes
NY
Thank you Adam for your input (sorry it took me a while to answer).
