Tires pressure
Bscanlon64
Just got new tires. Old ones were 245 new are 265. Pretty sure they filled them to about 70 psi... New tires are rated at a 80 psi max. It rides like **** and I feel every crack bump etc. Do I leave them at the pressure they set them at or should I stay true to what's in the door jamb?
98sporttj
west chester Ohio
2006 QCSB 4X4
4.7L
my nittos say 80 psi and i run them right around 40-50 psi i tried 80 once and well ya it rode like poo... drop the pressure and get ur ride back
quietpeen
2021 TRX
Hellcat
70 is way too much. Only time you would want to run them that high is if you are hauling a heavy load
lwszabo
Concord N.C.
Fill them to recommended pressure on the door jamb. Keep an eye on the wear on the edges and adjust from there. My guess if +5 psi for the oversized tire
NWRQC
What tires are they?
Bscanlon64
Bscanlon64
My door jamb says 50 from 80 rear....
Bscanlon64
Bscanlon64
It's an 05 2500 with Hemi FYI...
blackout11
alpharetts GA
2011 R/T
your best bet since you changed the size is to research it since you changed them you cant always go by door jam my advise call the whoever makes them and talk to them. But if it calls for 50/80 try that if they all have 70 then ya front is to high and back is to low
