Tires
Rav3ncroft
Indiana
2018 RCSB Sport
They would work on stock 20x9 but it's really not advised on 20x10. I'm sure others will chime in on this discussion.
Burla
2010 Hemi Reg Cab 4x4
You have to look at the specific tire, even within the same brand different tires have a range of rim size they will fit, your tire either meets it or not. If you go against the range, you are going against something tested by the manu.
heckcat9
UT
Most 275/65R20 tires are rated/tested for 7.5-9.5'' wide wheels (check the specific brand, model, and size for its exact wheel width range), as others here have stated.
They can be mounted on a 20x10, but the tire will be slightly stretched and the sidewall will be under a little stress. Might not ride too well but you'll get brownie points from the Euro and JDM guys for the hella flush stretch and poke stance. Not my cup of tea at all, but a lot of show trucks have stretched tires as well. :p Picture below is an extreme example, I think the tire width and wheel width delta is almost 2'' hahah...
nitto-nt420v-tires-paving-the-way-for-truck-suv-performance-tires-2019-07-08_14-05-06_083099.jpg
mtnrider
Georgia
They might fit but I am sure they are outside the manufacturers recommended width and I wouldn't run them. Definitely going to be "stretched"
