Topper third brake light Wire
Dennis Gulau
Central Michigan
5.9l, Ecodiesel, 5.7l
I have a 2018 2500 4x4.
I have a topper to put on and want to wire in the third brake light.
I've read that there is supposed to be a wire stubbed out of the factory harness that is for the third brake light in a topper but can't for the life of me find it.
Any tips on finding this mystery wire?
Or perhaps a different way to wire in a third brake light?
I believe is a Wht/Purple wire located about where the receiver mounts to the frame on the driver's side. That where I found mine(it a 1500 though), your should be in the similar area.
Depending on the topper, my Leer actually has a module that you wire the Left and Right trailer lights to and that turns the Third brake light on. The topper also has lights and power lock(that wired to the tailgate lock).
D
Dennis Gulau
Central Michigan
Thanks, that is where I've been looking. If it is there, It must be hidden well.
Tried my Google-Foo and came up with a video, it's of a '15 2500 though
In a description on another forum someone noted the wire was under the spare tire.
62Blazer
Midwest
Glad you found it. I was getting ready to reply that it was on the passenger side on my '16 2500 and to look there, but you beat me to it. There was only one wire on mine for the brake light so not sure what the others are for on the '18? For the interior lights in the topper I ran a hot wire all the way from the fuse box under the hood back to it.
D
Dennis Gulau
Central Michigan
I have the auxiliary switch option. The two extra wires are for battery power and ignition power through the aux switches if I want it.
WY-Dave
Air Force
Cheyenne, WY
6.7 CTD
Ancient thread, but this is where I got my info to search for it. I extended the wires on the topper harness and ran them and strapped the extended harness. I was looking for the fulltime power for the topper dome light and bupkiss. Neither had power no matter of off/acc/on. Incase we overnight somewhere in the bed, won't have to have the key in. Unstrapped everything and tapped off the 7way trailer hitch full time power in the bed.
Javier Aceves
Southern California
3.0 Ecodiesel
I have a 2024 Ram 1500 Crew Cab Laramie 4x4 and found the third brake light connection wire on the rear drivers side above the wire harness connector that is above the driver side tailpipe. Works perfect with my topper and a brake light isolator module was not needed.IMG_9483.jpeg
haleme
VA
I've been looking all over the place on the driver's side for the purple/white wire. After reading this thread, I lower the spare tire and found the third brake light wire. Thanks!
MRob
Colorado
Cummings
I just tapped into this on my 2026 RAM 2500. There are a lot of wires back there and more than few unused (probably depends on what options you have). The wire I used was a single smaller gauge wire coming off a larger bundle up above the spare a little on the passenger side. That wire supply’s 12V when the brake pedal is pressed and does not have 12V with either turn signal. I grounded to the back of one of the bolts for the hitch and ran both wires up through the bed behind the driver side brake light (light assembly comes off with two bolts). It’s working great. The Smartcap I bought comes with a wiring harness for attachment under the steering column. I decided to try this first.
