This would leave me to believe that it's an issue with the cap light, not your wiring. Only thing that comes to mind, would be is the cap lights LED? if so, maybe try switching the wires around. Maybe your hot/ground wires are reversed in the light.Ran a test on the light, light works with just power and ground. Been reading and it says to hook up to the purple and white which is how it was hooked up when I bought the truck but still does not work
Any luck?I will try to switch them and post my results later
