Torque specs transmission filter/pan?
anyone know the torque specs for the ZF8 filter/cover. For the flat head bolts that actually hold it to the tranny housing?
I can’t seem to find an exact answer.
BarbersBlue
Baytown, TX
BarbersBlue
Baytown, TX
I scrolled to the end and found a reference to an aluminum and steel transmission pan. Are these available?
PPE makes a heavy duty aluminium pan that holds roughly 1.5 litres more fluid,and has a replacable filter.I have one on my 8HP70,and like it.If you have the stock Y pipe,you might have to have a muffler shop tweak it slightly for clearance around the pan though.
https://www.xtremediesel.com/ppe-zf-8hp70-heavy-duty-aluminum-transmission-pan
Yes, I've seen that before. The ZF page implied (to me) that there was an OEM pan somewhere. That the aluminum pan has only one magnet concerns me some. Will have to do some more research.
I wouldn't worry to much about the 1 magnet,as it's a neo magnet which is noticeably stronger then the oem magnets.if it really worries you,you could always JB Weld another neo magnet into the pan,but I think the magnet being the drain plug is probably more then enough,if it doesn't collect everything,you're probably due for a tranny,lol.Maybe the ZF in other manufactures use a different pan,i've never looked at one in a Rolls or BMW,but as far as I know the FCA versions are all composite pans,i know the pan on my wifes A8 Challenger is the same pan as my truck has.The PPE pan is a very robust pan ie: heavy duty and is noticeably heavier then the stock pan
B
Sorry for the delay I’ve been away.
I clicked the ZF8 link and it’s a dead page?
You guys are right it doesn't appear to be there anymore. I copied the torque specs off it ,and they're posted above.The basic torque pattern is an ever widening circle,starting at the middle bolts.
PdPuNOme
Jersey
Thank you
mfifield01
Hemi 5.7l
I was just looking at the pan. There is one T40 bolt that sits above the exhaust. I have a 3/8" T40 socket. How did everyone torque that bolt down. My socket won't fit with a ratchet.
Most torx bits are removable from the socket,then use a wrench that fits the other end of the t-40 bit,and snug the bolt . I've never torqued the bolts on any ZF pan,i just use a 1/4" ratchet and go hand tight.
mfifield01
Hemi 5.7l
I purchased a bit at Lowes. My initial thought was to use it with a 1/4" socket on a the 1/4" torque wrench. It still didn't have enough clearance. I thought about cutting the bit, but starting testing other 1/4" sockets. I had an older universal kit that I used to keep in my camper. The socket was deeper and fits. In the end, I can still use the torque wrench.
Backup plan is/was to use a standard open end wrench with the bit and go hand tight.
Fatboy1989
