Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
Often the bolts on transmission pan seem to become loose enough to seep trans fluid. Is there an after market pan or a tip / trick to keep pan from seeping? Thank you in advance
Loctite will keep the bolts from loosening.
I switched to an aluminum pan , which has extra capacity to help with temperatures.
I have the six speed also.
