The TPMS receiver is in front of the driver front wheel. During winter it has a tendency to catch alot of debris from road grime. Suggest you look it over and even clear it of any debris. If you are a big off roader then the same applies with mud and crud.
In most cases a quick cleaning can correct most issues.
Tpms transmitters from MA Mopar will generally last 8 to 10 years. My 14 just had sensors replaced and my 16 still is on original sensors but on its 3rd set of tires. At about $50 and up per sensors if you purchase from Mopar, they tend to be the best if you keep your vehicle for many years.
If you trade frequently, then aftermarket sensors can work but their life may not be as long.
