Traction control light
louis whiteside
ms.
So i have a 2015 ram exspress 5.7 124k miles,i was driving on the interstare the other day and the traction control kight came on,i hooked my code reader up didnt throw a code just the iat sensor that has been nagging me for 6 months,anyone else have or know how to deal with this? Tyia
62Blazer
Midwest
There should be a code in the system and would suspect that your code reader simply isn't accessing it. Warning lights simply don't come on if there is not a code stored somewhere for it. I've seen several of the "cheaper" code readers that won't access the brake system codes (in which the traction control would be under). You will need to get ahold of a code reader that can access the brake system and see what specific code it is. There are many different codes that will trigger that light.
joshhhh
