SDutcher
So I have a 2016 Ram 1500 2wd 5.7 and it has the Service Trailer Brakes warning along with Service the electronic brake system. The trailer is not connected. I also loose the cruise control and the esc light is on. If I turn off the truck and then restart it goes away until I reach approximately 15 mph and then it’s back. I have checked the wheel sensors for open sensors and they check the same. Any suggestions? I have been to O’Reilleys and they couldn’t get any abs codes because it goes away when you shut the motor off.
