Trailer running lights always on
Las Vegas
Cummins 6.7
My trailer running lights are on permanently. I checked the F29 fuse, and it is good, when I pull it, the power goes out, so the fuse is good. I suspect the relay is frozen, but can't for the life of me figure out where the relay is, Googling only shows me 2004 and under where you have to remove and take apart the fuse box, I hope it's changed since then. The wiring diagram calls it the "Relay - Trailer tow park lamp", and is on a brown wire out of the Power Distribution Center (W756). On the 7-way, it is the top left connector. This should only be energized when the truck lights are on (hence, my suspicion that the relay is frozen closed, because mine is energized at all times, even with the ignition off).
Any help?
First post here, I'm desperate, but happy to join the community. I only bought the truck 2 weeks ago, and love it so far besides this.
Thanks,
David
Administrator
The relay is built into the Power Distribution Module (fuse panel).
You might want to check the wiring to the BCM. Keep in mind that the circuit is grounded through the BCM, that's how the circuit is controlled
  • TRAILER-TOW-SYSTEM.pdf
josheras
florida
where is to find the diagram electric for 18 ram 1500 sport hemi 5.7?. I have a problem with the 7 blade connector plug. When I applied brakes the running lights blade on in the connector.
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
Is your trailer wired correctly? The top 2 terminals are 12v charge and Parking lights. If the wires are crossed or touching inside the trailer plug the parking lights on the trailer will illuminate.
