atc06jh
- Feb 23, 2013
- 573
- 320
- Location
- Middle Georgia
- 2014
- Hemi 5.7L
Hey guys,
Looking for a little help here. Yesterday I decided to service my tranny, swap out some fluid and new filter. The filter kit from Advanced only came with the flat filter and not the round one too, does this make a difference? Also, the guy told me that I just need 5.5 qts to refill it cause thats all a service change drains. So, I put 5.5 qts in and ran it till "running or HOT temp" and checked it with the truck in N and parking brake applied. Dip stick showed the fluid level was just about the top "COLD" hole when it's supposed to be between the two higher "HOT" holes. I have half a qt left. Should I just pour that in there or will it overfill it? There are no leaks or anything so I guess I did good cleaning the pan and installing the solid gasket!
Any info would be great! THANKS!
