Tranny swap
Tteal235
So I don't think my transmission is going to make it past next winter. Also I'm not sure if there has been other threads on this but I'm curious if anyone knows some good sites or places to look for used or rebuilt transmissions and if there are any DIY tutorials out there? Feedback is greatly appreciated
ST-8
Car-part.com. My personal opnion is to get a junkyard trans. If you can do the swap yourself you can do it for around 500-600 +/- depends where your at
Tteal235
Tteal235
Do you know roughly if theres anything electrically, timing, gear set up, etc. I'd have to deal with. I'm not a super mechanic but I have an idea. I've never messed with a transmission though. Kinda intimidated by it.
HemiLonestar
Navy Badge Coast Guard
MD
THIS. It's cheaper to find a low mileage take out than to try to build/have built a stronger RFE when you start putting power to these things. Got my last one here.
Very straightforward, disconnect, drop, replace, reconnect. You can use any 2wd or 4wd trans, they're the same with the exception of the end. 4wd will have the t-case adapter and 2wd just a tailshaft where the yoke goes in. I'm assuming you have 4wd so it'll be a bit more of a headache dropping it than a 2wd. If you reuse your stock TC, mark at least one set of bolt holes; if you aren't then it doesn't matter. Mark where your driveshafts connect to the diffs. If it's the first time you've separated the engine and trans, once you've double and triple checked you got all the bellhousing bolts, it may take some wiggling to get them apart. Highly recommend you download the factory service manual (available on this site) and read through the procedure. Also keeo in mind you will need a quicklearn performed once you're done or you can run the risk of possibly damaging your replacement trans.
Tteal235
Tteal235
What is a quicklearn and how do I get that done. Also, I'm not totally understanding what you mean by get the markings and stuff. And it will be the first time. The factory is still on
HemiLonestar
MD
Quick learn resets the clutch value index in the PCM so it can shift properly, remember its a fully electronic transmission. If you're local I can do it, if not it's a dealer trip. Marking the things I recommended is to try and keep as much of the factory built balance as possible. If for the most part it goes back together the way it came apart you shouldn't have any vibration issues. Very first time I did this I didn't mark the flange to the rear diff and I ended up with a little vibration. Reclocked it 180° and it went away.
ST-8
You should be able to go to a trans shop to get a quick learn as well. That's what I did with my last trans, since it was only 2miles up the road I drove there.
ST-8
Hemilonestar we been advertising the **** out of car-part the last few days lol
HemiLonestar
MD
I know lol, but you can't beat the results. Trans and replacement dash for me.
Tteal235
Tteal235
I've been looking on the website. I'm not seeing much for my truck, transmission wise
ST-8
Idk if it's been updated but I think when I was looking for my trans last yr it didn't include 4.7 trucks in the search. I got my trans an converter out of a 4.7 ram so it should be able to work from dakota, Durango
HemiLonestar
MD
Any RFE will work, it's the programming in the PCM/TCM that determines how many gears it will use. I think my last one came out of a 4.7 truck.
Lil_Ram
Power tech 3.7L
Off topic but quick question on this regard. Doesn't the 4wd AT have a shorter output shaft or does it use like a spacer between AT and TC?
HemiLonestar
MD
I appreciate that makes my life a lot easier
No problem, just make sure you actually have an RFE, in a lot of the 3.7 vehicles they eventually substituted the RFE with the 42RLE (junk).
Lil_Ram
Power tech 3.7L
I'm fairly certain it's the RFE. Haha I'll have to double check and figure out what'll be needed from a liberty for my crossover. SAS and 4wd conversion haha fun
ST-8
The 42 crap was in the later 3.7s like 06+ I think. Your g2g
ST-8
Funny that we can bash on another trans besides the 545 on here haha
HemiLonestar
MD
Well when they take a FWD transaxle and turn it into a RWD/4WD trans and think that's a good idea...
