Which motor is in your truck?hey guys
i got my 21 ram classic about a month ago. i'm in canada and there is no transmission options up here
so i'm wondering how do i know if i have a 850re or a 8hp70?
5.7Which motor is in your truck?
3.6 or 5.7?
If you have a 5.7 HEMI then you have the5.7
The classics don't get the 8HP75 Fast,the 75 is only available in the new body style 5th Gens,if he has the 8 speed it'll be the 8HP70. Op do you have a dial shifter mounted in the lower dash to the right of the steering column,or is the shifter on the column. If you have a dial shifter you have the 8 speed,if you have a column shifter,you'll have the 6 speed RFE transmissionIf you have a 5.7 HEMI then you have the
ZF 8HP75 instead of the 850RE.
Do they still put the 6 speed in any models ?The classics don't get the 8HP75 Fast,the 75 is only available in the new body style 5th Gens,if he has the 8 speed it'll be the 8HP70. Op do you have a dial shifter mounted in the lower dash to the right of the steering column,or is the shifter on the column. If you have a dial shifter you have the 8 speed,if you have a column shifter,you'll have the 6 speed RFE transmission
In Canada they still have beenDo they still put the 6 speed in any models ?
Thanks, wild one.In Canada they still have been
