Rick_Hunts
I'm new to this 2019 Bighorn, was looking through the manual and I see it recommended changing the xfer case fluid every 10k
Seems extreme??
Seems extreme??
I think If it was required there would be a dot or x under the 10000 column.
No dots or x-s means it's meant to never be changed.
Sent from my Pixel 3 XL using Tapatalk
Good point, I should read more....
Xfer case not due until 120k
That's a whole lot of space in the manual to tell you to change it at 120k
Appreciate the guidance
I recently purchased a used Chevy and the transfer case fluid was nasty looking at 60k. Probably never been touched.
New vehicle purchases I always replace all the oils after initial break in and then follow whatever is published for severe service.
My RAM only has 20K miles and is under MaxCare Lifetime, but I will probably change the diff and transfer case fluids early (leaving the transmission alone for now).
