Transmission filter housing?
Jamcousi9
5.9 magnum
Howdy.. Being its nice out and the service is overdue I decided to change the filter in my trans (1998 ram 1500 4wd) and the filter I pulled seems to be a plastic housing with the filter inside. The auto store gave me a Hastings fiber filter with no housing, I can't see this being right.
J
Jamcousi9
5.9 magnum
The two are significantly different in depth, the plastic housing seems to have the filter inside however isn't accessible
99RamSport360
5.9L Magnum 360
Not sure I would use the new one. My filter was also a metal/plastic housing with a fiber filter inside, and the new filter I installed was the exact same. I would take it back and find a better one.
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
I used WIX and it was exactly like my old filter.
J
Jamcousi9
5.9 magnum
Against my better judgement I installed the Hastings and ran Penzoil synthetic, now when it gets up to temp it won't shift from 2nd to 3rd unless I take my foot off the gas. My local Dodge dealer can't seem to get the filter right, 3 weeks later and still mia. Going to a different dealer tomorrow to get the right filter and fluid then keep my fingers crossed.:party52:
J
Jamcousi9
5.9 magnum
O'reily is a great auto parts store, I drove out to Arizona in my Ramcharger and passed one on the way somewhere around Tennessee, they had a lot of stock on hand and very helpful even though all I needed was an air filter. I opened an account at Napa and so far it's all been garbage
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
O'reilly is definitely higher on stuff than Rockauto or the like, but when I need something NOW, it's definitely the way to go, IMO.
ParrotHead FA
5.2 magnum
I get a purolator filter kit from advance auto parts near my house, and it looks exactly like my stock filter, the metal/plastic housing with the filter inside.
Dave
99RamSport360
5.9L Magnum 360
Against my better judgement I installed the Hastings and ran Penzoil synthetic, now when it gets up to temp it won't shift from 2nd to 3rd unless I take my foot off the gas. My local Dodge dealer can't seem to get the filter right, 3 weeks later and still mia.crossed.:party52:
My truck does exactly this. I've heard that the bands need to be adjusted. Anyone have any advice?
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
Those filters are slightly different i believe. The one on the right is for 97 and older. The one on the left is 98 and up. I just did a service on a 96 and the filter is different from my 98 and 2000. Just a little tidbit of info.
dapepper9
Iowa/Nebraska Border
5.9L V8
yes the bands need to be adjusted if you've recently done a service but also how bad is the shift problem? I had the same thing as well as 3rd to 4th not wanting to go sometimes not at all, turned out to be the governor, spent the $200 and just replaced both the governor sensor and solenoid, fixed it. Might not be your problem so makin sure your bands are adjusted is a good start
KAKA
