Transmission help!!!
Tiretread
5.9L magnum
I have a 2000 Dodge Ram 1500 5.9L 46re. My trans went bad. I picked up a 46re out of a 98 Dodge Ram 2500 with the 5.9L. I swapped the electronic. I ordered the solenoid upgrade kit for the 2000 to put in the 98. It consisted of
  • Rostra dual pack shift solenoid – 3-4 and lockup
  • HD 50185 Borg Warner governor pressure solenoid
  • Rostra governor pressure sensor - transducer temperature sensor
  • Output speed sensor
  • Sonnax updated 3-4 accumulator spring
  • Governor pressure solenoid body gasket
  • now it’s working half ass. I have all 4 gears. But it won’t shift out of 2nd unless I let off the gas. Also starts out like I have a high stall converter.
  • It gives me two codes
  • P1740 Dodge Description
    The P1740 code will set if expected RPM drop is not achieved while attempting to engine TCC and/or Overdrive. The P1740code indicates malfunctioning torque converter or overdrive clutch.
  • and P1756 - Governor Pressures Solenoid Conditions
  • Any help or suggestions are greatly appreciated
