Transmission line?
Lilskooter
Athol
5.9 12 valve
Anyone know where i might find Transmission line from trans to oil cooler. 95 ram 2500 12 valve 47 trans. Tried two aftermarket line and they keep blowing off on the road. OEM from Dodge is back ordered.
grizzstang
Calgary, Alberta Canada
Go to a hose shop and get them to make you one from high pressure hose and threaded pressure connectors.
I did this for our old Chevy Blazer external oil cooler lines that would leak about a year after replacement with OEM lines.
They never leaked again.
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
Link below. My experience with local shop is theres such a markup on the fittings and the hose you'd spend more than just buying the kit. Plus the kit has it all figured out already.
Just a warning, do NOT overtighten the fitting in the trans. It will crack the case so just snug so it won't leak.
