Transmission moan
Mr Grumpy
Marieville, QC
I've had a poke through the site and not found anything related to my specific issue so here goes.
I have a '04 Ram 1500 quad cab Hemi Sport 4x4 with about 120,000 miles that I bought used in January.
The issue is pulling away from a standstill I get a brief moaning sound, I can't feel the trans slipping and it only seems to do it in 1st gear.
I was wondering if anyone has experienced this? if so is it a precursor to something more serious?
I have no idea when the trans fluid was last changed so thinking about changing that, what would be the best fluid to use? is it worth throwing one of those bottles of magic fluid in first? if so which one? or after the fluid change?
Any advice and insight gratefully received, thanks in advance.
moezer
Calgary
Could be that the trans is on it's way out, put a bottle of lucas anti slip
Sent from my SM-N950W using Tapatalk
Mr Grumpy
Mr Grumpy
Marieville, QC
Doesn't sound like a fan clutch, noise sounds like it's coming from under the back seat when you're driving.
LoneWolf3574
I've never owned a 4x4 so I'm not positive on this but that sounds to me like that is about where the transfer case would be located. Have you checked the fluid level or changed it?
Snake15eyes1998
USA
I wouldn't put anything into your transmission, until you know forsure where the sound is coming from. What color is the fluid? Red? Brown? Black? I would do a transmission service for sure. In my transmission, I run amsoil full synthetic. Not sure what that noise could be.
Mr Grumpy
Mr Grumpy
Marieville, QC
Well thanks to you all for your thoughts.
So I checked the fluid, it was a little low but well within limit, nice red colour, didn't smell burned.
I figured I'd try the cheapest solution first and work up.
To Canadian Tire this morning and bought a bottle of the Lucas stuff, my thinking being that if that doesn't work it's not likely to do any more harm and it'll just come out when I change the fluid. Warmed her up and poured the stuff slowly down the dipstick tube with it idling, checked the level, ran it through the positions and out for a road test. No Noise!
Seems to have worked, I'll know better when it's going from cold though.
Jason G Slabaugh
Rossville Indiana
5.7l hemi
Mine does that too only when its cold.. But only started after I changed brake pads and rotors. Doesnt do it all the time but worse when its damp out
joshhhh
