transmission
clearview
holland, ohio
I own a 2017 ram 2500 with 6.4 gas motor. The transmission is jumping, (slipping) out of 5th gear. Don't matter if it is in tow mode or not. And it doesn't do it all the time. It will hit 5th gear and all of the sudden the rpms will jump way up like you shifted into neutral. I took it to a local transmission shop, and they want to exchange the transmission with a remanufactured one.
I was planning on trading the truck in this coming spring, but it doesn't make much since if I put almost 6 thousand dollars into it for a new trans . Truck has 82000 miles on it. Anybody else had this issue or have any ideals, Thanks
gville35
