I've been having a little bit of a lingering issue with my automatic transmission. I know transmissions are the achilles for a ram, it has to do with the shifting. It likes to ride around 2,500 before it wants to kick into the next gear, sometimes a little bit higher. I had previously replaced the speed sensor and going to replace the filter and fluid. Ran into a gentleman awhile back who had one and mentioned something along the lines that sometimes the seals in the trans around the shift pins like to stick and replacing them can do the trick..? Curious if it's something I can do myself while I'm replacing the filter or do I need to get an overhaul. Any suggestions?? Preciate it!
