Truck Dies
HemiBabe
DFW
So I always start my truck in the morning before work and let it warm up. A few times in the last week, I come outside to leave for work, and my truck had died. What could the issue be? Something with the fuel?
bigtigga84
dela....where?
Huh...... That's weird. Still runnin ok? it's probably mad you sold all that stuff you had for it lol
HemiBabe
HemiBabe
DFW
LOL, prolly so! Yeah, it's still running great, no problems while driving
bigtigga84
dela....where?
Have you stayed in it or outside to see what its doing before it shuts off? probably won't if your watching it though lol.
Bad Habit
Land O Lakes
Modded 4.7l
maybe your idle is dropping low because of a bad tps? causing it to stall.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
How old is the battery? Are you having defrost on to bump up the RPMs also?
HemiBabe
HemiBabe
DFW
I will reset the TPS again tonight, good idea. the air is just on regular, not defrost, and the battery is only a little over a year old.
I haven't been out there to hear what it does, if it sputters or anything, but I was wondering if it was like the injectors? Maybe it needs some injector cleaner put thru it?
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Possibly, even if its not showing a CEL also try pulling any codes with your tuner.
05singlecabHEMI
Lilburn,GA
its funny you posted this... was leaving work last night, and my truck does the exact same thing. lettin it warm up while taking a smoke and it just dies. I think it may be the fuel pump on mine. cause when i went to start it back up it wouldnt...it would almost fire up you can hear it. It was like there wasnt a lot of fuel being fed into it. it was weird cause thats never happened. but as soon as it started it have no isssues driving.
HemiBabe
HemiBabe
DFW
I don't have a remote start or anything on mine, it's weird because that's what it reminds me of, lol. Mine starts right back up though.
That is ironic, Nick haha
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
2019 (2003 Forgottens SOLD and 2014 SOLD)
Hemi 5.7 (392 Hemi) 86 Ford .308 HO Roller
Mine stalled and had a hard time keeping idle after warming up and driving to work, so I added some gas treatment and it cured it so i was guessing the lil ol gas station i use has water in their tank as this has happened before, so also important to leave at least half a tank to avoid condensation in winter. These Tucks need to keep the Injectors clean when they get old but also found it can stumble or go into limpe mode during that tank/cleaning process, just some experiences to assist.
Casper
U.S. Navy (Ret.)
Springfield, VA
5.7L
Most fuel injector treatments will remove a certain volume of water from your tank.
You shouldn't run empty because of both fuel system cooling and condensation, but if you reguallry add fuel system/injecotr cleaner, whether or not they do anything for your injectors, they will absorb up to 10% of their volume in free water and allow it to run through your combustion chamber without harming your engine (deals with staturation levels of certain petroleum distillate solvents).
I have the 32 gallon fuel tank and would never cut myself off at 1/2 a tank. I tend to draw the line at about 1/4 tank if I haven't run any fuel treatment in a while.
Lucas Fuel treatment for example is cheap and comes in a large size. If you added that every couple of tank-ups during the cold months you probably wouldn't have to worry about water unless you are buying bad gas. Some folks question if these products do anything postive for injectors, valves or cylinders, but chemically they do help with water.
HemiBabe
HemiBabe
DFW
Alright, thanks guys :)
I am guilty of letting it go below 1/2 tank, I didn't know that about the condensation. Gonna get some fuel treatment today and fill the truck up.
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
Was it cold the morning(s) it happened? Because even in December it's been like 80 degrees. Lol.
HemiBabe
HemiBabe
DFW
LOL, ya no kiddin, it was on the mornings where i'd say it was like in the 40s haha
HemiBabe
HemiBabe
DFW
Well, I put some fuel cleaner in it and filled it up, hasnt died again yet, we'll see how this week goes lol
