Truck jerks when soft braking!!!
Soaringcook
hemi v8 5.7
my ram 1500 2wd hemi brakes ok when I fast brake, but when I brake softly it Jenks right at the end. I already greased the drive shaft and turned off the hill assis.
I leveled 2 inches and replaced the stock shocks with skyjacker 2 inch elevating hydro shocks. The jerking was happening before and after. It only happen at full stop.
dhay13
Sounds like a warped rotor. I have one on my 2500 with only 17,000 miles (had about 14,000 when it started).
Elevated 2013
Huntley, IL
Dhay or firetruck both could be right. It could also just be a caliper hanging a little. Most likely it’s the right rear or front since it’s jerking right at the end. Try lining up the sliding pins and the metal clips that the pads set in 1 at a time and inspect the pads for wear. Sometimes a caliper just hangs because it can’t release because of rust or just usage and it will grab when you don’t expect it to.
