Truck stalls and won't idle. Plz help
99ramrunner
Magnum 5.9
Ok so my truck won't idle I goes from 500rpm to 1500 and sometimes stalls out when I put it in gear, it runs good after I drive it for 30mins and it warms up but otherwise it won't idle or accelerate. I've replaced the PCM the crank sensor, distributer, cam sensor, all the plugs, wires, and the coil. And still don't know what's wrong with it any advice would be great!
ktm1217
White Mills, PA
5.2L 318ci Magnum
Have you tried the TPS, or IAC motor?
