Truck won't start
99ramrunner
Magnum 5.9
Hey guys! I'm new to the site so I don't know if this is the right place to post this or not but I need some help one this one, I've got a 1999 dodge ram sport with a 5.9 360 magnum and it won't start! Turns over fine but won't start, I just replaced coil, spark plugs, and wires, the ignition control module is smoking everytime I turn it over! Does anyone know why?
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
Spray starter fluid in th throttle body and turn it over. If it starts then dies then it might be the fuel pump.
Sent from my VS920 4G
quietpeen
2021 TRX
Hellcat
Welcome to rf.
Try what swamp life said. Good place to start
99ramrunner
Magnum 5.9
It's not the fuel pumb because I took off the fuel line and turned the key and fuel came out. So I'm not sure what's going on with it
09nitetrain
meriden ct
there is pick up coil under the distributor rotor that goes bad and or crank sensor. check for spark and check for injector pulse. for injector pulse use a 194 bulb and pull the prongs out straight and put them into one of the injector plugs and crank and see if it lights up. it will light up very dull so you might need someone to crank for you and you watch for light
Okiespaniel
Work, Shop, Computer
magnum, 5.9
There's obviousl;y an electrical issue with your PCM if it is smoking. Is it the PM itself or the wires? If the wires are melted you'll need to replace them. Then you can start troubleshooting.
If the box itself is smoking then it is junk. Something internally is shorted out and still getting enough power to burn. You'll have to replace it.
99ramrunner
Magnum 5.9
Does anyone know how much the ignition control module is?
jbmobbs
murfreesboro, tennessee
upgrade........put an msd or fireball ignition control system on it lol get more mpgs lol
99ramrunner
Magnum 5.9
Ok, do you where I could get one? And how much they would cost?
jbmobbs
summit racing or jegs could hook u up with he whole setup u can get msd at o'rilleys i believe.....bur i reccomend summit so u get full install instructions,,,
99ramrunner
Magnum 5.9
So I found the crank sensor wires were broken and rubbing so it shorting out and making the PCM smoke so I put in a new PCM and new crank sensor and fixed the wires! But it still won't start!? Does anyone know why? Or what I should check/replace?
