True duals?
1morepart
2019 Ram 1500 Quad Cab Hemi 3.92’s
Georgia
Does anyone run true duals on their Hemi? I’m thinking of running 2.5” pipe and two mufflers with an h crossover. Any downside? I’m keeping the cats on. JB
Ohio5pt7
Ohio
I do. No down side in my opinion and its sounds beast.
Sent from my SAMSUNG-SM-G891A using Tapatalk all grammar errors brought you by fat fingers and auto correct.
1morepart
1morepart
Georgia
What mufflers? X or h
Ohio5pt7
Ohio
No muffler magnaflow xpipe few feet from cats. Left the stock resonators
Ohio5pt7
Ohio
Drone isnt bad but there Is some. Its loud! Towing my 7500lb camper wakes the county I'm in lol.
1morepart
1morepart
Georgia
Any pictures of the exhaust?
Firebird
2019 Ram 2500
Is back pressure an issue with true duals?
Ohio5pt7
Ohio
Back pressure is sort of a myth as far as need you actually need very little just enough to not over flow. It's all about velocity so you just you just have to make sure you size it right. I plan to stay na so I stayed with 2.5in pipe and will do 1 3/4 long tubes. If I were FI I would have went to 3" and 17/8 LTs. The loss ppl feel is when they go to big and velocity and scavenging slows. Think of it the Same as you would breathing thru different straws. A normal straw you'll blow let's lay 15 seconds to fully exhale and you'll feel the "backpressure" aka restriction. Then you move hope to milkshake straw let's say it take 7 seconds this time but no pressure and the air coming out will be moving fast. Now move up to a snorkel itll like take take about 2 seconds but you'll notice the air will be moving much slower. When you have a long system velocity means everything open headers dont have that issue because they instantly expel the exhaust.
1morepart
1morepart
Georgia
Ohio5pt7
Ohio
Great link. Explained perfectly. How about a mid pipe conversation to stir the pot. H/x or nothing. Begin;)
Depends on your end goal. Xpipe helps a lot with scavenging more exotic tone. H helps some with scavenging but will have a deeper tone. Straight pipes of each bank is going to give a great sound but the weakest performance. A good y pipe will help as much as a h pipe.
Ohio5pt7
Ohio
CG2742
Mesa
I had an aftermarket y pipe on my 2013. Went to an x and had a huge improvement in response and acceleration.
Ohio5pt7
Ohio
14hemiexpress
6.4l
I know this is a 3rd gen but almost I identical to what you are talking about. This is on my old 06 I had. I did 2.5 in tubing dual magnaflow bullet mufflers with H pipe. I didnt really knowtice much of a difference in power but it sounded really good.
1morepart
1morepart
Georgia
Decided to try a 40 series single inlet/single outlet. Sounds good to me. No drone. Quiet in the cabin unless under load. Costs 70 bucks. I welded it in and deleted the rear resonators.
