Truetrac oil
Tyler Yates
Iowa
What gear oil are you guys running in the truetrac? See the truetrac unit recommends 80w90 and the ram rear end calls for 75w140.
Reactions: U&A
Burla
2010 Hemi Reg Cab 4x4
You can't go wrong with Redline or Amsoil SG. If you decide on the thinner oil these will protect the diff much better then some random otc fluid as the base oils will stick in the heat better and won't loose viscosity in use as well.
U&A
2016 3500 SRW
6.4 HEMI
If you’re installing an aftermarket carrier then you should listen to the manufacture.
If you’re breaking in a brand new one I would not run a synthetic. Do a couple real short intervals and then jump to synthetic
JMO.
Sent while firmly grasping my redline lubed RAM [emoji231]
Tyler Yates
Tyler Yates
Iowa
JMO.
Copy. Ill go with the 80w90 then.
Travelin Ram
Since the main wear areas that need film strength are the gears and bearings, I’d take Ram’s spec. Every manufacturer has lowered viscosity everywhere possible. They went with 75W-140 because of some issue with lower viscosity. IMO.
Depending on what temperature you’re operating at, the two oils are going to cross over each other anyway.
Unless you’re operating under some extreme loads, I doubt it makes a difference. Probably none of us could tell any difference in how it drives or how it wears.
TruTracs are not lube sensitive the same way clutch type diffs are.
Tyler Yates
Tyler Yates
Iowa
Rodge. I guess i go ahead with ram specs then. Cheaper to buy anyways
bm02tj
B C Canada
OE goes as light as possible for better fuel mile and do not care if dies after warranty is over
89grand
Phoenix, AZ
2019 RCSB
I have Truetracs f/r in my TJ Wrangler. They don't "recommend" synthetic oil, although I'm not sure it matter too much, and they don't recommend gear oil with friction modifier, and finding oil that doesn't have that, isn't super easy. I used some cheap basic 80w90 because it didn't have it.
Don't run synthetic with a True Trac,just hunt up the cheaper old style mineral gear oil.True tracs need a little bit of friction to operate properly and synthetic can cut the friction factor down to where it might not operate properly.I change the oil in my true trac diff yearly,but the old style mineral gear lube is cheap as hell,so it's not a big deal to change it.
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
I put synthetic in my true trac on my 69 and had to drain it right back out ! Its a big no no on a True trac.
Burla
Some Synthetics have many offerings to accommodate this style gearbox, ones without Friction modifiers and less then gl-5 rating, I think choosing the wrong stuff will cost you. They should have a spec?
They do Burla. This is from pg 52 of my set-up manual for my True Trac.
"True Trac units perform best when using GL5 mineral /petroleum based gear oil . Synthetic lubes are discouraged .Do not use friction modifier additives or lubes formulated with friction modifiers"
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
Yeap when I put in the synthetic oil it made the unit lock up then it would pop real loud and free its self then lock up , it sounded and looked like it was going to break a axle as I moved the truck. It was pretty violent sounding and looking.
I drained it put in none synthetic and it worked perfectly fine.
Burla
More info needed, which synthetic oil? Almost any group 3 synthetic you buy off the shelf will have lsd additive in the formula. I get it, they say use group 2 so just use group 2, but I'm saying some synthetic formulas offer benefits if someone wanted to use those. If not keep it simple use the group 2 stuff, group 2 is better than ever before because of the value of waxes, so more of these have been taking out then years past.
I'd just hunt up the mineral lube they recommend,it's not hard to find,and is cheap as hell.Rear ends ran for years on good old GL5 mineral based gear lube with-out issues,lol. I get mine at my local Canadian Tire,lol
joshuaeb09
Medina County, TX
The big issue with torsen type designs and synthetics is the impact on the worm gear function and torque bias. Certain designs are more forgiving of a synthetic than others and it all depends on how the unit was setup. If you want the Eaton designed performance parameters then the easy choice is the dyno 80W90 changed regularly with no guess work.
I have seen quite a few truetrac equipped mustangs running 75w90NS or even heavy shockproof that worked well, but you'd be taking a gamble for sure. Also noted that most of these cars were beat on heavily either road racing or autoxing with frequent fluid changes so it is certainly an edge case usage lol.
ram1500rsm
Trabuco Canyon, CA
Whatever you do don't go for the synthetic ones unless you know for a fact they don't contain FM. Most Synt diff fluids if not all of them have FM one way or the other.
Torco RGO 85w90 or 85w140 will work with the TT, NO FM
If picking from Autozone or Oreallys, cheapest conventional diff fluid typically won't have FM.
I used to use the Autozone brand 6$ per quart.
