TYC lights one turn signal brighter than the other
daveray9
All of a sudden one of the lights the running lights (yellow) are much brighter than the other side. Also getting a blinker light out warning. I have the canbus adapters and not sure if there are resistors inside? I have a 2012 with the TYC projector lights and have the adapters from retroshop.
skyline090
charlotte, nc
Have you experienced light condensation on your TYC projectors?
Sent from my SM-G965U using Tapatalk
daveray9
daveray9
Actually, yes.. on the one with the issue.
skyline090
charlotte, nc
I've got condensation on one lens, but not the other. I know it doesn't explain why one side is dimmer than the other (mine are equally bright) but maybe its contributed to a corroded contact somewhere on that one headlight which is causing the problem.
skyline090
charlotte, nc
In addition to my last comment, the condensation build up I've seen on my drivers side headlight runs mainly along the bottom; the whole length of the running lights.
daveray9
daveray9
Thanks, the one on mine with condensation is actually brighter... if it was dimmer that would explain things more. Weird!
